Is it possible to display error messages like in GeNIe when learning?
maghnie
Post by maghnie »
For example, when trying to train a network using the PC algorithm on a dataset with both continuous and discrete time series, this is the output that I get in GeNIe:
Can't start learning due to problems with data.
## Selected algorithm supports continuous or discrete columns, but they can't be used together.
CONTINUOUS:
<column_names>
DISCRETE:
<other_column_names>
On the other hand, this is the message I get with pysmile:
PC failed: SMILE Error -1 in function PC.Learn
According to the SMILE docs, -1 is just a "general error".
Is there a way to get more info about the error from pysmile?
Or is there a pre-existing function to check a dataset and its compatibility with any of the learning algorithms?
For reference, this is how I'm currently handling errors:
def learn_with_pc(dataset: pysmile.learning.DataSet) -> BayesianNetwork:
    pc = pysmile.learning.PC()
    try:
        pattern = pc.learn(dataset)
    except pysmile.SMILEException as e:
        logger.error(f"PC failed: {e}")
        return
Re: Is it possible to display error messages like in GeNIe when learning?
The output from GeNIe you've quoted is produced by GeNIe code, which runs before calling into SMILE.
The implementation of PC in core C++ SMILE actually produces limited text output in addition to error code, but it's just a single line (no list of discrete vs continuous columns in the dataset)
