I know the log likelihood is calculated with in the EM and other learning algorithms, but does there exist a function that takes an existing network and a dataset, then calculates the log likelihood sore, without necessarily learning parameters?
If not can you tell me how the log likelihood is calculated within the EM algorithm.
Thank you
is there a function for calculating the log likelihood?
annieraichev
Re: is there a function for calculating the log likelihood?
Sorry for the late reply.
The most recent GeNIe build, version 4.1.3724, has a command which calculates the log likelihood for the network/dataset combination. This is implemented by calculating the sum of log(P(E)) values for each record in the dataset.
SMILE will support this functionality in its next release.
