Hi there,
my colleague and I were looking at Tutorial 3 and the printNodeInfo function. We tested the rSMILE code and now we wanted to perform a similar operation with a hybrid BBN. We tested the code with two different HBNs and the R session got aborted multiple times. Keep in mind I'm fairly new to R and I did not dare to modify the function in any way. Is there a workaround so we can use this function with hybrid models?
Many thanks and bets wishes,
Camilla
printNodeInfo rSMILE on hybrid BBNs?
Re: printNodeInfo rSMILE on hybrid BBNs?
You cannot use the printNodeInfo function from Tutorial 3 to print non-CPT node values without any modification.
See Tutorial 7 (Continuous model) and Tutorial 8 (Hybrid model). There are examples of how to create, modify and read values from Equation nodes.
