rSMILE Network$clearEvidence
I am having trouble using the clearEvidence function. I was wondering: does it work on all kinds of nodes? It does not seem to work for chance nodes in my case.
CN
CN
Re: rSMILE Network$clearEvidence
ClearEvidence function should work on chance nodes. Can you share the code you think is not working?
Hi piotr,
I'm not sure I can share the network, however, it was something like this
```{r}
net$getNodeDefinition("mychance_node")
net$setEvidence("mychance_node", "present")
net$getNodeValue("mychance_node") # this shows that in the line above we've set the evidence as 100% present which is correct
net$updateBeliefs()
beliefs <- net$getNodeValue("my_target_node")
updateAndShowStats(net)
net$clearEvidence("mychance_node")
the line net$getNodeDefinition("mychance_node") gets me: 0.14 0.86 which is correct, it is not 1 0 anymore. The last line net$getNodeValue("mychance_node"), which I thought I would use to check if clearEvidence worked, gets me this:
Error in net$getNodeValue() : RSmile error occured
SMILE Error Occured in: Network.GetValue
ErrNo=1
I guess using net$getNodeValue is not the best course of action, as there is no value set after I clear the evidence, right?
Camilla
```{r}
net$updateBeliefs()
ErrNo=1
Camilla
Yes, you have to call net$updateBeliefs before getting node values.I guess using net$getNodeValue is not the best course of action, as there is no value set after I clear the evidence, right?
My experience is that the evidence doesn’t get cleared from chance nodes (neither does the virtual evidence), even after you update. So I don’t get the error message mentioned above but I still can’t clear the evidence. How can this be?
Could you please share the code that doesn't work? If you don't want to share it on the forum, you can email me at piotr@bayesfusion.com
Code below works fine with rSMILE 2.0.10
net <- Network()
handle <- net$addNode(net$NodeType$CPT)
net$setNodeDefinition(handle, c(0.2, 0.8))
net$updateBeliefs()
v <- net$getNodeValue(handle) # 0.2 0.8
net$setEvidence(handle, 0)
v <- net$getNodeValue(handle) # 1 0
net$clearEvidence(handle)
net$isValueValid(handle) # FALSE
net$updateBeliefs()
Note that:
- evidence is not cleared after updateBeliefs
- the node value has a 'valid' flag, which can be checked with isValueValid
- setting or clearing the evidence invalidates the value of the node
- node values are valid when updateBeliefs is successful
Dear Piotr,
Many thanks for the reply, I tested your code and in my network and I get some peculiar results. I can email you the network separately as I don't have the right to share it publicly but it's the one published in this paper https://hess.copernicus.org/articles/26/1261/2022/ and it's a hybrid network. I was hoping to use 'virtual evidence' on a discrete node whilst avoiding discretisation of the network.
My priors for the 'Crop Type' node are c(0.01,0.13,0.12,0.645,0.095)
I then run the network
net$updateBeliefs()
and get posterior probabilities
net$getNodeValue("CropType") c(0.0108, 0.1266, 0.1189, 0.6507, 0.0930)
my target node is actually Overland flow load OLR, which is a continuous node and I get 10,000 simulated posterior values with
net$getNodeValue("OLR")
Then I set Virtual Evidence - this will discretise the network - which is a problem - I would like to set virtual evidence to avoid discretisation
net$setVirtualEvidence("CropType",c(0.05,0.05,0.1,0.7,0.1))
net$isValueValid("OLR") FALSE
net$updateBeliefs()
net$getNodeValue("CropType") - gives me posterior probabilities 0.001041667 0.013541667 0.025000000 0.940625000 0.019791667
net$getNodeValue("OLR") - gives me posterior probabilities 0.72068871 0.09775436 0.18155693
Then I try to clear this virtual evidence
net$clearAllEvidence
net$updateBeliefs()
net$getNodeValue("CropType") - gives me the same posterior probabilities as above 0.001041667 0.013541667 0.025000000 0.940625000 0.019791667
net$getNodeValue("OLR") - very similar posterior prob. as above 0.71978332 0.09689689 0.18331979
It seems that the virtual evidence 'sticks' and does not get cleared from the chance node? I would expect the network to revert back to continuous, when all evidence has been cleared?
Also, why does the network get discretised, when I set virtual evidence on a chance node - even when that node is a parent node? But perhaps I should start a separate post about this second problem?
Thank you
Miriam
net$updateBeliefs()
net$updateBeliefs()
net$updateBeliefs()
Thank you
Miriam
Are you using rSMILE 2.0.10? There were changes between this version and previous ones that could affect the results when using various Virtual Evidence methods.
Also - can I ask you to share the xdsl file by email or in a private message on the forum? I tried to replicate this behavior with another hybrid network with similar ancestor-descendant dependencies and the network behaved differently - after calling clearAllEvidence and updateBeliefs the getNodeValue method called on Equation Node returns array with generated samples.
Hi Piotr, yes, I'm using rSMILE 2.0.10
I'll send the network in a private message - many thanks!
I think you forgot the parentheses calling the clearAllEvidence function.
Change this code:
to this code:
in your script. Clearing the evidence in the network that I got in PM works as intended - after calling clearAllEvidence, the contiguous node returns samples.
Change this code:
net$clearAllEvidence()
OK, many thanks, a simple error!
