Documentation tab in the Node Property sheets
The documentation sometimes refers to the Documentation tab in the Node Property sheets that doesn't seem to exist. For example, this is mentioned several times in the Spreadsheet view of Diagnosis. How can I access this feature?
Re: Documentation tab in the Node Property sheets
We have made modifications to the user interface between GeNIe 3.0 and 4.0 and removed this tab from node properties. The functionality is still available through the spreadsheet interface (columns on the right hand side of the spreadsheet). Our interactions with users of the diagnostic extensions indicated that few users accessed the documentation tab through node properties. Do you feel the need for that tab? If so, is it for browsing the documentation links or for entering them?
I am not 100% sure if we need it yet. It can be useful to keep everything we can in BayesFusion. But we will probably use our GUI longer term. (I was just letting you know the difference between the doc and the software.)
