CPTS Query
CPTS Query
Please share your ideas if there is any method/technique where we can insert probabilities into the Bayesian network based on the weights of the variables calculated by methods such as AHP,ANP,SIMOS method?
Re: CPTS Query
AHP is a completely different technique that some people compare to multi-attribute utility functions. I don’t believe there is any straightforward way to combine AHP with probabilities. Hence no straightforward combination with Bayesian networks.
I hope this helps.
I hope this helps.
