SMILE 2.0 released. Binaries for M-series Macs available, interval-based nodes and metalog distribution supported now.
SMILE 2.0 is now available at https://download.bayesfusion.com. This version of the library supports metalog distributions and discrete nodes based on intervals or point values.
SMILE fully supports Macs based on M series (Apple Silicon) ARM CPUs. The C++, Python and Java libraries are available as universal binaries, containing both ARM and x64 code. The wrapper for R is available as separate binaries for ARM and x64.
roman
Re: SMILE 2.0 released. Binaries for M-series Macs available, interval-based nodes and metalog distribution supported no
Post by roman »
Thank you for releasing SMILE 2.0. The available documentation of SMILE and its wrappers is for version 1.6, can it still be used? Are there breaking API changes to be aware of? Thanks!
You can use your existing code with SMILE 2.0. We're preparing the documentation refresh.
The revised manual for SMILE 2.0 (the core C++ library) is available at https://support.bayesfusion.com/docs/
Enjoy! :)
