exporting output of influence diagram
orochisob
Post by orochisob »
Hi, Is there any way to export the outputs of the influence diagram to a text file or something else? As my network consists of several nodes and I will have to create graphs from the results, it would be nice if that was possible. I see the "Generate data file" option but it is not working with the influence diagram. Thank you in advance!
Re: exporting output of influence diagram
You can open the Value page in node properties, and copy the utilities from there. The numbers are copied in the text format, which can be pasted into any text editor or spreadsheet.
If you want to run over multiple sets of evidence/decisions, and get utilities for each case written to a file, it can be automated with a SMILE program.
orochisob
Post by orochisob »
Thank you for answering. Ok, I will have to try the smile engine then.
