SMILE.NET Error -1 on learn method
s.bakunowicz
Post by s.bakunowicz »
Hi. I'm trying to learn network from file and randomly get error -1 for generated file. File works fine on GeNie so I assume there's something wrong on SMILE or, most probably, in my code/file.
Example file:
exampleDataset.txt
(227.34 KiB) Downloaded 1052 times
What I do is simple load DataSet from file, creates new NaiveBayes object, set ClassVariableId and call Learn method on NaiveBayes object. Error is occurring on Learn method.
So it's something like this:
var ds = new DataSet();
ds.ReadFile(filePath);
var naiveBayes = new NaiveBayes
     ClassVariableId = classVariableId
naiveBayes.Learn(ds);
Same error occurred on BayesianSearch.
I'm generating those files by splitting main dataset on k-parts and some of them works but some of them not, in theory they are identical.
Thanks in advance.
Re: SMILE.NET Error -1 on learn method
The spcop column in your data file is constant and cannot be used for learning.
To get more detailed error messages, use GeNIe's Data/Learn New Network command.
s.bakunowicz
You're right, thank you!
