import pysmile error in Lunix system
Post by Yang Yajie »
hi, I am going to using the HPC system to test my code because the dataset volume is heavy.
I load python first in Lunix. the version of python is "Python 3.8.2 (default, Jul 31 2020, 20:59:58) [GCC 9.3.0] on Linux ".
Then I copy the pysmile_license.py, pysmile.pyd, pysmile.so file in the WinSCP as below figure1.
after that, I load python in lunix system. then I pip install some related packages include "pip install pysmile". then in python, I import pysmile and pysmile_license, it showed "ImportError: /home/yyang/pysmile.so: invalid ELF header". In figure 2.
Could you please tell me how can I deal with this problem? I need to created DBN in the lunix system.
thanks.
Yajie
figure 2.png (63.07 KiB) Viewed 17355 times
figure 1.png (66.46 KiB) Viewed 17355 times
Re: import pysmile error in Lunix system
Post by piotr [BayesFusion] »
It is probably a mismatch between the PySMILE and Python version installed.
Remove pysmile.so and pysmile.pyd from directory you are trying to run program, then uninstall locally cached PySMILE package by typing:
python -m pip uninstall pysmile
in your terminal.
Next, download recent version of PySMILE with command:
python -m pip install --index-url https://support.bayesfusion.com/pysmile-A/ pysmile
Python should show a successful download message - something like this:
Collecting pysmile
  Downloading https://support.bayesfusion.com/pysmile-A/pysmile/pysmile-1.6.0-cp27-cp27mu-linux_x86_64.whl (1.5 MB)
     |████████████████████████████████| 1.5 MB 173 kB/s
Installing collected packages: pysmile
Successfully installed pysmile-1.6.0
If you do not get any errors at this stage you should be able to use PySMILE. Try it by typing e.g.
import pysmile
import pysmile_license
net = pysmile.Network()
in Python console. Note that License file should be present in the folder.
I hope it helps.
I download the pysmile package in python and pysmile.so file in the download website page, and put the pysmile_license file in the WinSCP, then run my code in Lunix system. it showed "the ImportError: dynamic module does not define module export function (PyInit_pysmile)" as shown in the figure. Could you please tell where I was wrong?
Thanks very much!
It seems you installed Pysmile package from official pip repository - it is package unrelated with our PySMILE.
First - you have to uninstall this package with command:
Next - remove pysmile.so file from your directory and install from our index by typing:
Command above should install PySMILE version matching with Python version on your Linux system.
If installation is successfull you can use PySMILE by simple import in your Python script.
I uninstall pysmile first succesfully, then i remove the pysmile.so file out from WinSCP, then I download the pysmile by the code you sent to me"pip install --index-url https://support.bayesfusion.com/pysmile-A/ pysmile". it shown I download the pysmile package successfully as below figure 1. however, when i "import pysmile"and "import pysmile_license" in jupyter hub by access the lunix system, it shows error as below figure 1.
when i access the code package by putty access to the lunix system, i can import pysmile and import pysmile_license as figure 2. but i plan to access the lunix system by jupyter hub website. Could you please what should i do next?
Pip installs PySMILE from local cache. You have to uninstall PySMILE again (pip uninstall pysmile) and install with command: "pip install --no-cache-dir --index-url https://support.bayesfusion.com/pysmile-A/ pysmile"
