Error with data set matching for parameter learning
EAly
Post by EAly »
I'm trying to perform parameters learning for a network I created using pysmile, however, I get the following error when trying to
 match_network
SMILEException: SMILE Error Occured in: DataSet.MatchNetwork Dataset column 'ind_1_5_1' is continous, but matching node is discrete
ErrNo=-51
So as far as I understand, the possible solutions for this error is either to change the type of the node or do some data manipulation -although I'm not what change do I need to do to the data-. So if I'm to change the type of nodes, can I do that after creating them, something like "set_node_type"? and can I create an equation node and do the learning without defining a node equation?
I would appreaciate if you can also suggest a better solution?
Thanks in advance for your help
PS. Attached is the datafile, but couldn't attach the network .xdsl file because of its big size
All_variables.csv
Data file
(85.65 KiB) Downloaded 1197 times
Re: Error with data set matching for parameter learning
You need to discretize your data before parameter learning if your nodes are discrete. ind_1_5_1 contains values like 46.29 - SMILE can't map this onto a discrete node.
EAly
Post by EAly »
Thanks for your reply Shooltz,
but is there an option to do it the other way around, i.e. make the node continues without defining an equation?
No, the continuous nodes in GeNIe/SMILE are always defined by the equation.
