Good afternoon, when running this data giving the smile when the GENIUS of some problem. Could you see why this is happening? Because it is connected to the dll and I don't have access.
https://drive.google.com/file/d/1M9NVNA ... sp=sharing
C# error
Attempted to read or write to protected memory. This is usually an indication that another memory is damaged.
Configuration RB:
Max parent Count:1
Interations:300
Sample Size:300
Link Probability:0.5
Prior Link Probabity: 0.5
These were the only settings that managed to make the problem work, otherwise an exception -42 always appears.
