Apply the BBN to a table of cases
nzsk
Post by nzsk »
Is it possible to apply a discrete or continous BBN in Genie to a whole table of cases at once and save the simulations in a new column? I know it's possible to load a case and run the BBN in the interface but is it possible to apply the BBN to many cases at once and save the output as a new column in the same table?
Re: Apply the BBN to a table of cases
Yes, just load the network and data, then use 'Validate' command from the main menu. GeNIe will display a dialog box where you can specify if you want to perform a cross-validation, or just test the network without any learning. Select 'Test' and enter the file name of the output file at the bottom of the dialog box.
nzsk
Post by nzsk »
Fantastic, thank you for the quick reply, I'll try this. with best wishes Miriam
nzsk
Post by nzsk »
It doesn't appear possible to apply a hybrid network to a table of cases. This only seems possible with a discrete network. Is this correct? Many thanks.
That's correct. This functionality is currently only supported in discrete networks.
