Most determinant nodes
liid
Post by liid »
Is there an option (GeNIe or smile) to understand what are the most determinant factors/nodes of my BN? and to somehow quantify the size of the effect they generate?
manman
Re: Most determinant nodes
Post by manman »
What about trying to use the strength of influence?
liid
Post by liid »
Thanks for the suggestion, but strength of influence does not capture what I need (that is, understand the most influential variables on my target node, and somehow quantify this influence).
You can consider using sensitivity analysis. It will give you the measure of the influence of each parameter of the network on the posterior probability of the selected target node and its outcome.
manman
Post by manman »
I think the suggestions of sensitivity analysis is the correct choice.
