Hi all,
I would like to have more insights on training a BN with a node that is completely hidden. Can I do that?
A small illustration to make things clearer:
I am building a network for the purpose of monitoring some variations in the performances of an electronic circuit. These variations cannot be extracted directly, but I know that they are correlated to sensors that I can measure. My strategy is then to build an intermediate hidden node V representing these abstract variations and link it to the values given by the sensors (and the circuit performances).
In essence, V is completely unknown during training (= composed of only missing instances). My current strategy is to include V in the network and give e.g. 5 possible values that it can take, but I'm not sure I can do that. In the dataset, V is a column composed of only missing instances. But when I assign the nodes and dataset columns in the "Match Network and Data" window, it then assigns State0 to the value 0 (that is never given in the dataset, all instances for V are missing) and the four other states at given at (unassigned).
After training, what I see is that among the 5 values that V can take, the probability of V=state0 is almost 1, and of course the probabilities of all other states are nearly zero.
Am I doing something wrong ? Or is this not handled/ not possible to be done?
Thanks in advance!
Training with a completely hidden node
Re: Training with a completely hidden node
EM in GeNIe does not require that every node has an associated data column. GeNIe will attempt to match as many node/column pairs as possible, based on the identifiers.
If V in the dataset has only missing values, either remove the column V, or drag the V node to the left list to ensure it is not associated with the V column in the dataset (dragging V column to the right will also work).
Oh actually that was easy :)
Thanks a lot it works well now !
