Hello to everybody,
Is there any way that I could use some (not all) states of a discrete node in the definition of an equation node?
Thanks and kind regards,
Evan
Numerical operations between node’s states in hybrid networks
- operations_in_hybrid.xdsl
- (5.15 KiB) Downloaded 2424 times
Re: Numerical operations between node’s states in hybrid networks
Absolutely! Generally, you will want to use conditional expressions. If you want to refer to labels (state names), here is an example of a definition:
If(slow_onset_phenomena="Under",1,2)
There is an example of reference to the state name through function Choose () in GeNIe Manual (section "Hybrid models").
