Hey, I'm reasonably new to GeNIe and having built a Bayesian network I am trying to test it using data not include in the training set used by the structure learning algorithm.
Is there a feature that will allow me import a file with multiple cases and output the outcome of the network in each case?
I understand the Case Manager tool, but it does not allow for external data to be loaded into the Case Library and inputting a large amount of cases may become tedious :/
And then once the cases are loaded, is there a method to determine the outcome of the network without having to update the network with each case individually?
Thanks in advance
Testing model on out of sample data
Re: Testing model on out of sample data
You can do that - use the 'Open data file' or 'Import ODBC data', then select 'Copy cases' option from the 'Data' menu (assuming that target network file is open).Snarf wrote:I understand the Case Manager tool, but it does not allow for external data to be loaded into the Case Library and inputting a large amount of cases may become tedious :/
Unfortunately, this is not possible using GeNIe only - but you can do that easily with SMILE, jSMILE or Smile.NET.And then once the cases are loaded, is there a method to determine the outcome of the network without having to update the network with each case individually?
