Create network and learning strecture and parameters
azzedine_fcb
Post by azzedine_fcb »
Hello
I have a database I want to create network and learning structure and parameter
What steps should I take?
if exist example any langage c++ java .... send to me please
thanks
Re: Create network and learning strecture and parameters
For learning in SMILE you'll need your data in a dataset object (DSL_dataset in C++, smile.learning.DataSet in Java). You can either export your database content as a text file and use DSL_dataset::ReadFile, or create your own dataset by calling its methods. Note that SMILE does not provide direct database import features.
If you're using C++, see Using SMILE/Datasets and Using SMILE/Learning chapters in SMILE Manual at https://support.bayesfusion.com/docs - the manual was recently updated to include information related to learning.
azzedine_fcb
thanks
