SMILE.COM GetAllNodes
jdtoellner
Post by jdtoellner »
Can you show me how the SMILE.COM GetAllNodes method works?
jdtoellner
Re: SMILE.COM GetAllNodes
I figured it out.
Sub GetNodes()
	Dim Nodes As Variant
	Nodes = Net.GetAllNodes()
End Sub
This assumes you already had opened a network.
Dim Net As SmileNetwork		'Has to be accessible to the function below
Set Net = New SmileNetwork
Net.ReadFile("Network.xdsl")
The following will work as well:
Dim a
a = Net.GetAllNodes()
To iterate over the array, you can use LBound and UBound:
Dim a
a = s.GetAllNodes()
for i = LBound(a) to UBound(a)
    dim nodeid as string
    nodeid = a(i)
    rem do something with nodeid
next
jdtoellner
Here's another way to iterate over an array:
Sub DisplayNodes()
	Dim Node As Variant
	Range("A1").Select
	For Each Node in Nodes
		ActiveCell.Value = Node
		ActiveCell.Offset(1,0).Select
	Next Node
End Sub
