Compiling SMILE in Matlab
lib
Post by lib »
I am using SMILE in a Matlab/Simulink model, which uses a so called
S-Function. When I compile the model, the error "SMILE INITERR 00" appears
recursively on the console, the program never finishes compiling and Matlab
crashes. I am using Matlab 2016a under Ubuntu 16.04.
Thanks.
Re: Compiling SMILE in Matlab
SMILE relies on its private global C++ object to perform license initialization. The error you're getting (SMILE INITERR 00) indicates that the constructors of global objects in SMILE were not invoked on startup. It's probably caused by the compiler settings used to build the executable with your S-function.
We have just received another report about SMILE INITERR 00. The problem was caused by a global DSL_network object, the constructor of which ran before licensing key was initialized. If you have global DSL_network in your program and want to keep it, please replace this:
DSL_network n;
void someFunc1() {
    // use n here
void someFunc2() {
    // use n here
with this
DSL_network& GeNetwork() {
    static DSL_network n;
    return n;
void someFunc1() {
    // use GetNetwork here
void someFunc2() {
This ensures that DSL_network's constructor runs after the initialization of your SMILE licensing key.
