Can it be because I did not clear the belief?System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at DSL_network.{dtor}(DSL_network* )
I don't know if someone face this problem before, I am using C# and C++ with smile.h to develop a web service. everything is fine, deploy it to the IIS server, I loop for few time to read the xsdl fie, i get this error:
Re: System.AccessViolationException
No, I would check the return value of FindNode call; maybe your 'node' parameter is incorrect (node identifiers in SMILE are case-seensitive).Can it be because I did not clear the belief?
