Case Management
ddavis
Case Management
Post by ddavis »
The case management tool/facility causes an exception. Can you suggest what might be causing this? Model attached, I attempted to add several cases to this in order to toggel between a base, high and low. The exception occurred when I attempted to save. I'm using GeNIe 2.0.3717.0 on a Windows XP machine.
CMEP Model 3.xdsl
(24.54 KiB) Downloaded 993 times
Re: Case Management
I can't reproduce the problem. Can you check with most recent GeNIe test build available at http://genie.sis.pitt.edu/download/genie2_binaries.zip ?
If the problem persists, please provide more information regarding cases you're trying to save (which nodes/outcomes are used).
ddavis
Post by ddavis »
Thanks. I used the version you linked to and it seems to work fine. A bit quirky when switching between cases (doesn't seem to like immediate update and only works with the first case listed - you have to sort them) At least, that is my first impression. As a new user of GeNIe I very much appreciate the quick response on this forum. Thanks again!
