SoftEvidence => Uncaught Exception
diana
Post by diana »
I have been trying to make use of the SoftEvidence feature provide by smile, but for some reason I keep getting: uncaught exception error message even for the simplest code:
vector<double> evidence;
evidence.push_back(0.20);
evidence.push_back(0.80);
int ok = theNet.GetNode(success)->Value()->SetSoftEvidence(evidence);
Note: For this testing I used the net provide in the wiki tutorial.
Anyone with experience on the subject? Any ideas?
Thank you
Diana
Re: SoftEvidence => Uncaught Exception
diana wrote:vector<double> evidence;
Check the return value of GetNode call before proceeding.
diana
Post by diana »
theNet.GetNode(success) returns 0 ( i.e. it is successful)
Also I can set "normal" evidence with SetEvidence:
theNet.GetNode(success)->Value()->SetEvidence(ev);
But with SetSoftEvidence, it just fails terminates.
Diana
diana wrote:theNet.GetNode(success) returns 0 ( i.e. it is successful)
The return value of DSL_network::GetNode is DSL_node*, not integer.
theNet.GetNode(success) returns NULL pointer and it's definitely not successful. Check the value of 'success' parameter - it's not a valid node handle.
