jsmile + R software
alex
jsmile + R software
Post by alex »
I just started working with jsmile + R, following the tutorial in the wiki.
rJava package was successfully installed and loaded as well as JVM started.
But I get the following error when try to declare an instance of a network:
net = .jnew("smile/Network")
Error in .jnew("smile/Network") : java.lang.ClassNotFoundException
Could you give me some hints?
Best
Re: jsmile + R software
When launching the JVM with .jinit you need to ensure that classpath and java.library.path are correctly set.
.jinit(classpath="<full name of the smile.jar file, including directory>",
parameters="-Djava.library.path=<directory where jsmile.dll or jsmile.so is located, without filename>")
Note that when you use RGui on Windows and you've called .jinit without parameters or with parameters specified incorrectly, you'll need to restart the RGui, because JVM is only launched by first .jinit call. In such case, restart the GUI and try again. I'm not sure how this works on a Mac or Linux.
