Setting node colors
jdtoellner
Setting node colors
Post by jdtoellner »
I'm able to set node colors to a nice light pink with a darker pink border with this code:
theNet.GetNode(observableNodeHandle)->Info().Screen().color = 0xeeb4e2;
theNet.GetNode(observableNodeHandle)->Info().Screen().borderColor = 0x9d3b88;
When I try this color however I should get blue node with a darker blue border but I get a burnt orange instead:
theNet.GetNode(nodeHandle)->Info().Screen().color = 0x3e8fc3;
theNet.GetNode(nodeHandle)->Info().Screen().borderColor = 0x2c6e99;
Here's what it looks like:
jdtoellner
Re: Setting node colors
It looks like the Red and Blue colors are reversed. If I display the network in Genie I see:
R - 195
G - 143
B - 62
The correct color is:
R - 62
G - 143
B - 195
The colors are represented as rrbbgg in XDSL file. Internally SMILE uses Windows API convention for ordering red/green/blue components (again, for historical reasons). If your program runs on Windows and you include windows.h, you can use RGB macro to initializer colors:
theNet.GetNode(nodeHandle)->Info().Screen().color = RGB(62, 143, 195);
