Hello, I am new to the forum. I"m a graduate student working on belief networks and their application to ecology. I went through all of the tutorials yesterday, and am in the process of trying to learn the parameters for a belief network I have setup.
I keep running into a runtime error, though. I noticed in a previous post that this might be related to the amount of available RAM on my computer. I'm working on a laptop with 1 GB of RAM, and no other applications running. Is this not sufficient?
I am happy to attach the network and the discretized dataset, if necessary. Thanks in advance. I'm really enjoying the GeNIe program!
Microsoft Visual C++ Runtime Error
will.s.barnett
Re: Microsoft Visual C++ Runtime Error
That entirely depends on the network and the evidence set.will.s.barnett wrote:I'm working on a laptop with 1 GB of RAM, and no other applications running. Is this not sufficient?
Yes, post the files here.I am happy to attach the network and the discretized dataset, if necessary.
will.s.barnett
Thanks for taking the time to look at this. The network and dataset are attached. I also added a comment that explains the correspondence between the nodes and the column names in the data.
- bn07_discretized.zip
- There are several variables in the dataset that do not have nodes. In addition, the node identified as veg corresponds to "veg07", "WaterPrev" corresponds to dat$X06Wk1, and "Water" corresponds to dat$X07wk1.
- (1.73 KiB) Downloaded 809 times
will.s.barnett
Thanks for checking into the error. Maybe I don't understand the nuances of Noisy-Max nodes very well, but shouldn't they simplify computation? I thought that the conditional probability table of the child node (in this case, Milfoil) would be huge if I left it as a "Chance-General" node, and would have much fewer entries with the Noisy-Max designation.
They simplify modelling. Computation requires separate code paths activated when noisy nodes are present, or simply uses expanded CPT.will.s.barnett wrote:Maybe I don't understand the nuances of Noisy-Max nodes very well, but shouldn't they simplify computation?
The crash you've found is in the noisy-specific part of EM.
