Hello Genie&Smile-Community,
i didn't succeed in setting soft evidence within the case manager. Having lots of soft evidences it's a problem to handle them manually. Is it possible to integrate the feature of handling soft evidence within the case manager?
Greets
Consideration of soft-evidences in the case manager
joergweber79
Re: Consideration of soft-evidences in the case manager
It's certainly possible and it's even in the TODO list for GeNIe.joergweber79 wrote:i didn't succeed in setting soft evidence within the case manager. Having lots of soft evidences it's a problem to handle them manually. Is it possible to integrate the feature of handling soft evidence within the case manager?
joergweber79
joergweber79
Still no soft evidence in case manager
Unfortunately i noticed, that in the most recent version of genie it's till impossible to save / edit soft evidence via the case manager. Can you tell me, if and when this feature will be implemented? I really need this functionality for my work.
Thanks in advance and keep up good work.
Greetings
Joerg
Greetings
Joerg
Re: Still no soft evidence in case manager
Current estimate for the delivery of this feature is before the end of April 2010.joergweber79 wrote:Unfortunately i noticed, that in the most recent version of genie it's till impossible to save / edit soft evidence via the case manager. Can you tell me, if and when this feature will be implemented? I really need this functionality for my work.
Soft Evidence and Fuzzy Bayesian Network
I am student on second year Master's of search "New Technology and Dedicated Computer System" and I work on Fuzzy Bayesian Network (FBN) ...
I think that this axis is very similar to the notion " soft evidence "..
What you think of that?
And if you can explain to me the functioning of " Soft Evidence "?
Thank you in advance
joergweber79
When will the new version including the save functionality for soft evidences be released? I really need this feature to analyse my results. Thank you.shooltz wrote:Current estimate for the delivery of this feature is before the end of April 2010.joergweber79 wrote:Unfortunately i noticed, that in the most recent version of genie it's till impossible to save / edit soft evidence via the case manager. Can you tell me, if and when this feature will be implemented? I really need this functionality for my work.
Unofficial release with soft evidence support in case manager can be downloaded from:
http://genie.sis.pitt.edu/download/genie2_binaries.zip
Unzip the file onto existing GeNIe install.
