Hi
I'm constructing relatively complicated net. After an attempt to add new arc I'm receiving Runtime Error. "This application has requested the Runtime to terminate in an usual way." How can I avoid that?
Exception: Visual C++ Runtime Library
Re: Exception: Visual C++ Runtime Library
Most likely reason is that the CPT for the node with new incoming arc can't fit into available memory. Note that every CPT entry is 8 bytes, and number of entries is the product of outcome count of the node and outcome counts of all of its parents.io5120 wrote:I'm constructing relatively complicated net. After an attempt to add new arc I'm receiving Runtime Error. "This application has requested the Runtime to terminate in an usual way." How can I avoid that?
