Possible bug in matrix dimensions after structure learning
thom
Post by thom »
After learning the network structure (with PC as well as with GTT) I wanted to do something with the prob. matrix. When I do the following:
DSL_Dmatrix * probMatrix = n.GetNode(n.FindNode("A"))->Definition()->GetMatrix();
DSL_intArray dimensions = probMatrix->GetDimensions();
cout << "Dimensions are";
for(int i = 0; i < dimensions.NumItems(); i++) cout << dimensions[i] << " ";
This does not output any of the dimensions. When I debug in visual studio, it seems that the array 'dimensions' does contain some items. However, NumItems() is equal to 0.
I used to following data to test this:
A B C
s6 0 1
s6 0 1
s0 0 0
s0 0 0
s0 0 0
s0 1 1
s0 1 1
s0 1 1
s0 1 1
s6 0 1
s6 0 1
I'm pretty sure I can find a way around this problem. However it might be worth to take a look at it and possibly fix it.
-Thom
Re: Possible bug in matrix dimensions after structure learni
You were hit by a problem going back to the beginning of SMILE development. The author of the DSL_xxxArray classes was trying to model them on std::vector and its resize() and reserve() methods, but failed. Hence we have NumItems and GetSize. This is of course a complete mess. The rule of thumb is: always use NumItems, unless you're dealing with DSL_xxxArrays in DSL_Dmatrix - in such case GetSize is the method to call.
Sorry again for the confusion, but this stuff is basically baked into SMILE - the classes are used across large code base.
