Outcome order in node properties
Edu_Ayra
Post by Edu_Ayra »
Hi all!
When I select "High to low" outcome order it has no effect!!
Could anybody help me??
regards
Re: Outcome order in node properties
This property is used in canonical gates, such as Noisy-MAX. They require states to be sorted from high to low or from low to high (they will accept both and just use simple negation to pick the one that they want). I hope this helps -- Marek
