More Smilearn tutorial compilation problems
ermutarra
Post by ermutarra »
I'm trying to compile the first Smilearn tutorial but I'm running into problems.
The error message is exactly the following:
nnn@nnn:~/SMILE/tutorial$ make
g++ -O3 -DNDEBUG -ffast-math -c tutorial1.cpp -I/home/nnn/SMILE/lib
g++ -O3 -DNDEBUG -ffast-math tutorial1.o -o tutorial1 -L/home/nnn/SMILE/lib -lsmile -lsmilearn
/home/nnn/SMILE/lib/libsmilearn.a(dataset.o): In function `DSL_dataset::MatchNetwork(DSL_network const&, std::vector<DSL_datasetMatch, std::allocator<DSL_datasetMatch> >&, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&)':
dataset.cxx:(.text+0xca0): undefined reference to `DSL_network::FindNode(char const*) const'
dataset.cxx:(.text+0xdc0): undefined reference to `DSL_stringArray::FindPosition(char const*) const'
/home/nnn/SMILE/lib/libsmilearn.a(dataset.o): In function `DSL_dataset::ReadFile(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, DSL_datasetParseParams const*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
dataset.cxx:(.text+0x2abe): undefined reference to `ErrorH'
dataset.cxx:(.text+0x2ac7): undefined reference to `DSL_errorStringHandler::LogError(int, char const*, char const*)'
make: *** [tutorial1] Error 1
Re: More Smilearn tutorial compilation problems
The problem is most likely related to the order of the libraries in gcc's command line. Try this:
g++ tutorial1.cpp -O3 -DNDEBUG -I/home/nnn/SMILE/lib -L/home/nnn/SMILE/lib -lsmilearn -lsmile -o tutorial1
ermutarra
Post by ermutarra »
This solved this problem. Thank you!!!
