I've tried to use DSL_em to learn the parameters of a three node network with the dataset from (http://genie.sis.pitt.edu/wiki/Tutorial ... Tutorial_4).
However, it seems that the learning is never successful (DSL_em::Learn(...) doesn't return a DSL_OK).
I wonder if I made any mistakes in using DSL_em? Is there a place where I can find a example on using it?
Following is my code segment.
Thanks.
DSL_dataset d;
DSL_idArray someNames;
d.ReadFile("c:\\temp\\b.txt");
DSL_network result;
DSL_em em;
int nc = result.AddNode(DSL_CPT, "c");
int nx = result.AddNode(DSL_CPT, "x");
int ny = result.AddNode(DSL_CPT, "y");
someNames.Add("State0");
someNames.Add("State1");
result.GetNode(nc)->Definition()->SetNumberOfOutcomes(someNames);
result.GetNode(nx)->Definition()->SetNumberOfOutcomes(someNames);
result.GetNode(ny)->Definition()->SetNumberOfOutcomes(someNames);
result.AddArc(nc,nx);
result.AddArc(nc,ny);
em.SetEquivalentSampleSize(10);
if (em.Learn(d,result)!=DSL_OKAY)
cout << "Learning failed." << endl;
return;
result.WriteFile("c:\\temp\\em.xdsl");
b.txt:
c x y
State1 State1 State0
State0 State1 State1
State0 State0 State0
State0 State0 State1
State0 State1 State0
issues with DSL_em
Re: issues with DSL_em
Try calling d.MatchNetwork before the learning (but after the nodes have been created and initialized).
shooltz wrote:Try calling d.MatchNetwork before the learning (but after the nodes have been created and initialized).
That fixes the problem. Thanks a lot:)
