I am new to Genie. While working on tutorial 12 - Sensitivity Analysis, I am not able to define the states in node properties as indicated in the tutorial.
Please see the attached document with screenshots (both as in tutorial and in my model) for the reference.
I am using Genie v 2.0.3092.0
I would appreciate if someone could help me with this.
With Regards
Sundar Iyer
Sensitivity Definition
- Screenshot Node Properties.doc
- Screen shots of Node properties
- (89 KiB) Downloaded 1596 times
Re: Sensitivity Definition
The screenshot in the docs shows the 'General' page of node properties with diagnostic extensions enabled. In such case it's possible to add/remove outcomes using 'General' page. To enable diagnostic extensions (not really needed for tutorial 12), select 'Enable Diagnosis' from the 'Network' menu.
You can also manage node outcomes from the 'Definition' page - this does not require any changes in the settings. This is the primary user interface for this activity.
Hi Shooltz,
Thanks for your reply. It worked..
Regards
Sundar
Regards
Sundar
shooltz wrote:The screenshot in the docs shows the 'General' page of node properties with diagnostic extensions enabled. In such case it's possible to add/remove outcomes using 'General' page. To enable diagnostic extensions (not really needed for tutorial 12), select 'Enable Diagnosis' from the 'Network' menu.
