Check error
hylx
Check error
Post by hylx »
I am learning a dataset using PC algorithm, but I cannot get any model. I know there is a header file named "error.h", but how I can check what is the error that is , how to return the error information by calling what function besides ErrorH.RedirectToFile(stdout)?
Thanks.
Re: Check error
Can you post your source code?
hylx
Post by hylx »
I attach the code. Thanks so much.
pc learning.cpp
(5.75 KiB) Downloaded 1459 times
Your code uses the obsolete version of SMILE. Currently, DSL_pc returns DSL_pattern (which, if it's a proper DAG, can be converted to DSL_network with a call to DSL_pattern::ToDAG).
