Smile linking with GCC windows
pilar
Post by pilar »
Hi all,
I'm new with C++ and I am using CodeBlocks for the moment. I've tried to compile VC version of Smile and also gycwin_gcc but none of them link correctly...
It seems I'm missing something, some linkage errors I'm not being able to solve with forums...
Here the first errors I get, but all of them are the same:
C:\work\Smile_vc8\main.cpp|20|undefined reference to `DSL_network::DSL_network()'|
C:\work\Smile_vc8\main.cpp|23|undefined reference to `DSL_network::AddNode(int, char const*)'|
C:\work\Smile_vc8\main.cpp|26|undefined reference to `DSL_idArray::DSL_idArray(bool)'|
C:\work\Smile_vc8\main.cpp|27|undefined reference to `DSL_idArray::Add(char const*)'|
C:\work\Smile_vc8\main.cpp|28|undefined reference to `DSL_idArray::Add(char const*)'|
Main.cpp is the example one in the SmileWiki, it includes "smile.h".
If someone could help me, please, I'm not able to solve it on my own and I'm getting mad.
Thanks very much,
Pilar
Re: Smile linking with GCC windows
You'll need to tell the linker to use smile.lib (automatic linking is only supported in Visual C++). I've never used CodeBlocks, so I can't give you more assistance, other than pointing to section 1.11.8 in the CodeBlocks online documentation.
pilar
Post by pilar »
Thanks very much but I had already tried to link manually and it does not work.
Finally, I've changed to VC... :(
cs
Linux
Post by cs »
I have the same problem using the linux version of smile. Although i have linked smile with -lsmile, I get the same error message like mentioned above.
Does someone know a solution for this problem for a linux machine?
Re: Linux
Can you post your gcc command line here?
