I already designed the structure of a network. I want to learn the parameters. There are questions as follows:
There are no training data for a root node in my network. I have prior experience to assign its value. So, how can I hand this problem when I use the EM algorithm? Is it a good idea to generate data accruing to the prior knowledge and then add the data to the missing column in the training data set?
Another question is that, there are some unobservable node (hidden node) in the network. Can I still employee EM to learn the parameters?
Thank you so much!
Regards,
Yang
How to combine the prior knowledge during learning
Re: How to combine the prior knowledge during learning
If you want EM to keep the node's parameters unchanged, include it in the fixed nodes set (it's one of the parameters passed to the learn method as vector or array, depending on the language you're using).There are no training data for a root node in my network. I have prior experience to assign its value. So, how can I hand this problem when I use the EM algorithm?
The parameters will be learned even if no data is associated with the node (unless you explicitly assign the node to the fixed node set).Another question is that, there are some unobservable node (hidden node) in the network. Can I still employee EM to learn the parameters?
