g++ compiling issue
Gardiola
g++ compiling issue
Post by Gardiola »
Good morning
I use g++ as a compiler ( and Eclipse for my C++ development ).
I copied all the files and then created a small test.
#include "smile.h"
///#include <utility>
using namespace std;
int main()
DSL_network theNet;
I got the following output
15:50:46 **** Incremental Build of configuration Debug for project TEST ****
Info: Internal Builder is used for build
g++ -O0 -g3 -Wall -c -fmessage-length=0 -o "src\\Main24.o" "..\\src\\Main24.cpp"
In file included from ..\src\Main24.cpp:34:0:
..\src\/smile.h:26:6: error: #error SMILE : in debug build the runtime library must be set to Multi-threaded Debug DLL
In file included from ..\src\/smile.h:77:0,
..\src\/caselibrary.h:7:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
In file included from ..\src\/smile.h:43:0,
..\src\/simplecase.h: In constructor 'DSL_simpleCase::Item::Item(int)':
..\src\/simplecase.h:109:16: warning: 'DSL_simpleCase::Item::continous' will be initialized after [-Wreorder]
..\src\/simplecase.h:107:7: warning: 'int DSL_simpleCase::Item::type' [-Wreorder]
..\src\/simplecase.h:105:9: warning: when initialized here [-Wreorder]
15:50:46 Build Finished (took 359ms)
Any view on this ?
Thanks for this.
Didier
Re: g++ compiling issue
Try adding -DSMILE_VC_NO_AUTOLINK to the compiler command line.
Gardiola wrote:I use g++ as a compiler ( and Eclipse for my C++ development ).
BTW: if you use MinGW then you'll also have to define NDEBUG - we only provide SMILE library binaries with debug info for Visual C++.
Gardiola
Post by Gardiola »
It looks like that Visual 2010 C++ will be more easy to add the dll. let s try this one. Didier
Gardiola
Post by Gardiola »
I struggle to add a dll with Visual 2010 Express.
so at the moment I am stuck with my current issue... I use MinGW
how I can do that ?
how I can do that ?
Thanks for this
Didier
how I can do that ?
I have no idea - never used Eclipse with C++. It must be somewhere in the project settings.
Re: Visual Studio - you don't add a 'dll' to use SMILE. You'd be using a static library (a file with the .lib extension)
Gardiola
Post by Gardiola »
I installed VC++ 2010 and I added the static lib in the linker - > General - > additional library directories.
It works !
now I need to learn your formalism before to come back to you.
Thanks for your help.
Didier
