Parameters learning with jSmile
dtodor
Post by dtodor »
I'm using Visual C++ Express Edition (Version 9.0.30729.1 SP):
Microsoft Visual Studio 2008
Microsoft .NET Framework
Version 3.5 SP1
Installed Edition: VC Express
Microsoft Visual C++ 2008 91909-152-0000052-60665
Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB945282) KB945282
This hotfix is for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU.
If you later install a more recent service pack, this hotfix will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/945282.
Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB946040) KB946040
For more information, visit http://support.microsoft.com/kb/946040.
Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB946308) KB946308
For more information, visit http://support.microsoft.com/kb/946308.
Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB947540) KB947540
For more information, visit http://support.microsoft.com/kb/947540.
Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB947789) KB947789
For more information, visit http://support.microsoft.com/kb/947789.
Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB948127) KB948127
For more information, visit http://support.microsoft.com/kb/948127.
Here is the code of the test application:
#include <iostream>
#include <vector>
#include "smile.h"
#include "smilearn.h"
int main (int argc, char * const argv[]) {
	DSL_network network;
	if (network.ReadFile("abc-h-def-network-randomized.xdsl") != DSL_OKAY) {
		std::cout << "Unable to read network\n";
		return -1;
	std::cout << "1. Successfully read network\n";
	DSL_dataset dataset;
	if (dataset.ReadFile("abc-h-def-network-original.txt") != DSL_OKAY) {
		return -2;
	std::cout << "2. Successfully read data set\n";
	std::string errMsg;
	std::vector<DSL_datasetMatch> matches;
	if (dataset.MatchNetwork(network, matches, errMsg) != DSL_OKAY) {
		return -3;
	std::cout << "3. Successfully calculated matches\n";
	for (unsigned int i=0; i<matches.size(); i++) {
		const DSL_datasetMatch &m = matches[i];
		printf("%d col=%d slice=%d h=%d %s\n", i, m.column, m.slice, m.node, network.GetNode(m.node)->GetId());
	std::vector<int> fixedNodes;
	DSL_em em;
	//em.SetEquivalentSampleSize(2);
	em.SetRandomizeParameters(true);
	if (em.Learn(dataset, network, matches) != DSL_OKAY) {
		std::cout << errMsg;
		return -4;
	std::cout << "4. Successfully learnt network\n";
	if (network.WriteFile("abc-h-def-network-learnt.xdsl") != DSL_OKAY) {
		return -5;
	std::cout << "5. Successfully written learnt network\n";
	for (int h = network.GetFirstNode(); h >= 0; h = network.GetNextNode(h))
		printf("%d %s\n", h, network.GetNode(h)->GetId());
		const DSL_Dmatrix *mtx = network.GetNode(h)->Definition()->GetMatrix();
		for (int i = 0; i < mtx->GetSize(); i ++)
			printf("%g ", (*mtx)[i]);
		printf("\n");
    return 0;
Under Mac OS X 10.5 I get the following results:
0 col=0 slice=0 h=0 A
1 col=1 slice=0 h=1 B
2 col=2 slice=0 h=2 C
3 col=3 slice=0 h=3 H
4 col=4 slice=0 h=4 D
5 col=5 slice=0 h=5 E
6 col=6 slice=0 h=6 F
0 A
0.5005 0.4995
1 B
0.4925 0.5075
2 C
0.5275 0.4725
3 H
0.195312 0.804688 0.518448 0.481552 0.584179 0.415821 0.86999 0.13001 0.0174197 0.98258 0.808501 0.191499 0.162883 0.837117 0.782767 0.217233
4 D
0.201708 0.798292 0.677407 0.322593
5 E
0.588047 0.411953 0.643097 0.356903
6 F
0.323372 0.676628 0.386902 0.613098
	em.SetRandomizeParameters(false);
0 A
0.500759 0.499241
1 B
0.492636 0.507364
2 C
0.527896 0.472104
3 H
0.195727 0.804273 0.518448 0.481552 0.584179 0.415821 0.86999 0.13001 0.0174197 0.98258 0.808501 0.191499 0.162883 0.837117 0.782767 0.217233
4 D
0.20216 0.79784 0.677407 0.322593
5 E
0.588571 0.411429 0.643097 0.356903
6 F
0.324728 0.675272 0.386902 0.613098
The results for Windows XP SP3 are as follows:
0 A
0.5005 0.4995
1 B
0.4925 0.5075
2 C
0.5275 0.4725
3 H
0.195313 0.804688 0.725738 0.274262 0.361217 0.638783 0.289796 0.710204 0.172932 0.827068 0.884956 0.115044 0.451852 0.548148 0.763713 0.236287
4 D
0.201708 0.798292 0.703669 0.296331
5 E
0.588047 0.411953 0.478833 0.521167
6 F
0.323372 0.676628 0.0903104 0.90969
0 A
0.500759 0.499241
1 B
0.492636 0.507364
2 C
0.527896 0.472104
3 H
0.195727 0.804273 0.724004 0.275996 0.362899 0.637101 0.294494 0.705506 0.171772 0.828228 0.884285 0.115715 0.449727 0.550273 0.763873 0.236127
4 D
0.20216 0.79784 0.70362 0.29638
5 E
0.588571 0.411429 0.479142 0.520858
6 F
0.324728 0.675272 0.0908674 0.909133
Thanks for the support!!!
Network
(3.11 KiB) Downloaded 1554 times
Training data
(49.21 KiB) Downloaded 1601 times
Due to issues with our internal network I'm unable to connect to the machine which has VM with Darwin, so I can't directly verify your results. However, I checked that the numbers you reported on XP; they match those I'm getting on my Windows box with Visual C++ and cygwin. Output from the program running on FreeBSD is also the same.
While I'm waiting for the admins to complete their job, can you check the gcc version on your OSX computer with gcc --version ? Also, what's the command line you're using to build the program?
dtodor
Post by dtodor »
I'm actually using XCode with gcc 4:
i686-apple-darwin9-g++-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5493)
I've also tried building from the command line:
g++ -O3 -DNDEBUG -ffast-math main.cpp -o test -Lsmile -Ismile -lsmilearn -lsmile
I'm getting the exactly same results as when using XCode. And these are different from what I get under Windows.
I have just confirmed your findings on Darwin running in VM (so it's certainly not an issue of OS/compiler version mismatch). We'll be trying to identify the reason for the output discrepancy and will post here as soon as any information is available.
At this point it looks like the issue with gcc's optimizer. The output is incorrect only if -O1/-O2/-O3 options are used to build SMILE/SMILearn. However, these options do not cause problems when gcc is used on other platforms (we don't have a system with gcc 4.0.x though).
dtodor
Post by dtodor »
Could you provide a build without any optimizations?
dtodor wrote:Could you provide a build without any optimizations?
We'll do it as a last instance. Currently we're trying to determine where the codepaths diverge on different platforms.
We've found the loop which is executed incorrectly when compiled with optimizations enabled on Darwin. It's quite easy to work around this gcc 4.0.0 bug and we'll post new build for OSX later this week compiled with -O3.
dtodor
Post by dtodor »
Thanks for the support! Would it be possible to make a x86_64 build as well?
dtodor wrote:Thanks for the support! Would it be possible to make a x86_64 build as well?
I believe gcc 4.0.0 on Darwin 8.0.1 only supports i386 and ppc architectures. If you can point me to downloadable Darwin installer CD with gcc support for x86-64 I can try to set it up in a VM later this week.
SMILE binaries for OSX have been refreshed. This is a build with -O3.
