PC learning in Java
Branislav
PC learning in Java
Post by Branislav »
I have problem with generating network using PC alg. in Java. All I have is just pattern. This pattern is not DAG and I don't know how to turn it into DAG in Java.
Here's my code:
Network net = new Network();
DataSet ds = new DataSet();
ds.readFile(sfile);
initNetwork(net, ds, tagcnt); // my method
DataMatch[] matching = ds.matchNetwork(net);
final PC pc = new PC();
pc.setMaxAdjacency(8);
pc.setSignificance(0.05);
Pattern pt = pc.learn(ds);
if(!pt.isDAG())
// some code to convert it to DAG???
Can you tell me please what exactly means pattern.setMaxAdjacency(int) and pattern.setSignificance(double)?
Thanx for help :)
B.
Re: PC learning in Java
Branislav wrote:I have problem with generating network using PC alg. in Java. All I have is just pattern. This pattern is not DAG and I don't know how to turn it into DAG in Java.
The pattern is the output from the PC algorithm. SMILearn (and jSMILE) does not contain any functionality for DAG conversion - you'll need to convert pattern to DAG from your code with the calls to Pattern.setEdge, or use GeNIe and manually make the pattern into a DAG.
These methods apply to the PC class, not Pattern class.
