Calculating the probability of evidence across equation nodes
maghnie
Post by maghnie »
(This post is specifically about the Python wrapper of SMILE)
Can prob_evidence(...) be called on a network with equation nodes?
For reference, prob_evidence() works for me just fine on networks trained with BS (and CPT nodes).
However, after creating a network with PC (using the same training data), calling prob_evidence() causes my script to crash without any error messages.
Genie (academic version) also crashes when trying to get the Log Likelihood using the same data set and trained network, but I chalked it up to my many open tabs and programs.
On an unrelated note, this "silent crash" also happens if I try to call get_outcome_ids() on an equation node. But at least the incompatibility here between equation nodes and trying to get their "outcome ids" is expected and could be avoided.
Re: Calculating the probability of evidence across equation nodes
Thanks for the bug report, we will ensure the silent crashes do not occur (the program should generate a Python exception instead of crashing, of course).
Regarding P(e) for equation-based networks, I'll need to ask our theoretical division. Will post answer here once I know it.
Probability of any evidence in a continuous node will be zero, so you cannot do that even theoretically. I suggest that you discretize your network first and then calculate P(E). You can make the interval around the evidence as small as you want but not empty/zero length.
maghnie
Post by maghnie »
Thanks for the replies and suggestion!
Chance nodes with small bins seems to be working great for now, but I will keep the discretization idea of equation nodes in mind for future reference.
