User-defined PDF function
charlie
Post by charlie »
Hi Administrator
I got a problem with the self-defined probability distribution function - CustomPDF in using the equation node.
Please see attached two sample nodes, one defined as a uniform distribution, the other a quite evenly spaced uni-model distribution. However the displayed pattern is very confusing - the first node not only displays a non-uniform distribution but also show a large empty space in the middle. The 2nd node also shows a large empty space in the middle which is not featured in the original data to define the PDF.
Could you help with that?
Charlie
CustomPDF.xdsl
(1.24 KiB) Downloaded 1396 times
Re: User-defined PDF function
The CustomPDF function requires the x coordinates (the first half of function arguments) to be in increasing order. Your equations have descreasing x ordering.
BTW, please check your private message inbox on this forum.
charlie
Post by charlie »
Thank you Shooltz.
Charles
