I was wondering if it makes sense and it would be possible to remove the constraint in the Confidence parameter in the 'Learn Parameters with EM' dialog box that limits values to integers. Theoretically they can be any non-negative values, right?
Adam
Confidence in the Learn parameters with EM dialog
Re: Confidence in the Learn parameters with EM dialog
You are right and we will make the change. Thanks for the feedback.
