exporting results sensitivity analysis
laurap
Post by laurap » Mon May 07, 2018 10:51 am
Hi all,
I think the sensitivity analysis tool of GeNIe is really great.
I saw I can copy the final graph as png and use in other software. However I would like to have access to the results (numerical values) of the target node, but also of the different nodes, to do further analysis. Is this possible?
Thanks a lot in advance
Best wishes
laura
Re: exporting results sensitivity analysis
Post by marek [BayesFusion] » Tue May 15, 2018 2:50 pm
Hi Laura,
I'm afraid the only thing that you can copy and paste from the dialog are the tornado diagrams. Just right-click on the diagram and then select Copy. You can paste the copied diagrams in a program like Word. If you want access to the other numbers, like derivatives in the sensitivity calculations, you will need to use SMILE from within your program. I hope this helps.
laurap
Post by laurap » Wed May 23, 2018 7:25 am
Hi Marek,
thanks for this. I will look into SMILE then.
Laura
