time-dependent CPT in Genie
normanwang
Post by normanwang »
Can Genie and Smile deal with time-dependent CPTs ?
My case is that I want to build up an DOOBN and estimate the CPTs based on physical equations .However, the equations are time-dependent with all the variables(except the time variable t) following normal distributions, which means the relationship between two time slice are changed with time. Currently, most cases assume CPT are identical all the time, so I think I am really stuck by this problem. I appreciate any help from you!!! The attachment is the detailed description of one of equations. Hopefully you can give me some inspiration. Many thanks.
question.doc
(74 KiB) Downloaded 1141 times
