Import a test set
student
Import a test set
Post by student »
I've trained my network with a trainings set.
Now I want to test it with the test set.
Is there a possibility to import the complete test set and compute it or have I to choose the evidence for each node by hand?
Re: Import a test set
student wrote:I've trained my network with a trainings set.
The closest thing would be using Data|Copy Cases command, which would create the set of cases in the network. You would be able to apply the evidence using entire cases, representing the rows in the data set (as opposed to setting evidenec on each node by hand).
You can of course use SMILE, jSMILE or Smile.NET to automate the process completely.
student
Post by student »
Thanks, that's much better!
