I have been use SMILE for a while
Some error occur due to Update-Beliefs fails
Can you giving me some advice to avoid this kind of error?
1.reduce the number of child_nodes
2. set some interesting target
3. modify model
Wei
About Error (-42): UpdateBeliefs fails
Re: About Error (-42): UpdateBeliefs fails
Most propably your model became too complicated to get computed. -42 error simply means that you are getting out of memory during computation.
You are indeed right that you should:
1. Reduce the number of parent nodes so that your CPTs aren't that large. You should get familiar with parent divorcing techniques.
2. Always set the target node that is interesting.
You can also experiment with different algorithms such as EPIS sampling.
Good luck,
orzech
Good luck,
orzech
