I'm new to SMILE and Influence Diagrams, so I have one naive question... I have a structure of ID, and I would now like to populate the CPTs. In every sampling interval, I get the values of all observables which are described in the ID. How to populate the tables? What is the general approach?
Nikola
novice question...
Oh, I think I've used the wrong words in my previous post, and I'm afraid I don't understand your answer...
Let say that I have the structure of the ID/BN, and populated CPTs for each node. Now, I get new observations, and I want to embed it into the CPTs. How to do that? Should I start from the root-chance nodes, and go down the network, updating the counts for each node? Or there is some more elegant way?
Nikola
Nikola
I have two questions...
1. how exactly Normalize() works?
2. Is there a better way of updating CPTs for a node, then this algorithm:
Since there is a lot of multiplying and dividing of doubles, we can loose precision. Also, count needs to be kept for each node in a separate global table. Is there any better method?[/code]
count <- number of observations for a Node
foreach dimension in CPT
p <- probability in the CPT
if this is the dimension we need to update
p <- (p*count+1)/(count+1)
else
p <- p*count/(count+1)
end if
probability in the CPT <- p
end foreach
Let me clarify what I meant with counts. Let's say we have three variables, A, B, C, and A, B, are parents of C. To estimate the entry in the CPT for C where the states of all the nodes are 1, you would have to do the following: Count(a1,b1,c1) / Count(a1,b1), where Count is the number of joint occurrences in the data set. The division is the normalization and you never have to actually multiply with the probabilities in the CPTs.
