How to change the Userproperties
musicpxg
Post by musicpxg »
Hi, I am using the Jsmile. I want to change the value of a node user property, using the following codes. It doesn't work.
smile.UserProperty[] nodeproperty = net.getNodeUserProperties(handleID);
for (int i1 = 0; i1 < nodeproperty.length; i1++)
if (nodeproperty[i1].name.equals("Get_evidence_function") )
//nodeproperty[i1].value = "the new value";
It said "NameError: name 'the new value' is not defined"
I do not know how to do. Can anybody help me?
Re: How to change the Userproperties
You need to call Network.setNodeUserProperties when you're done with modifying the UserProperty objects. The array returned by getNodeUserProperties contains copies of C++ SMILE strings (which can't be modified directly from Java).
