How do you use filter in DSL_dataset? How to construct a filter to pass to DSL_dataset.ApplyFilter()? I would like to apply a filter to select some variables in a dataset for structure learning by smilearn. I see you are able to select variables in Genie, but can you do it in smilearn? Thanks.
Regards,
Peter
How to apply filter in DSL_dataset
Re: How to apply filter in DSL_dataset
Hi Peter,
The filter function is not for filtering variables but for filtering records.
If you want to select a subset of variables I recommend making a copy of the dataset and then removing the variables you are not interested in.
If I remember correctly, this is how GeNIe does it under the hood for the structure learning algorithms.
Best,
Martijn
Best,
Martijn
Thanks, Martijn. Your reply is very useful.
