Degree of Influence and Sensitivity Analysis
amirsad
Re: Degree of Influence and Sensitivity Analysis
Post by amirsad »
since sensitiviy.h is included in the current distribution of SMILE, I was wondering if it is now officially public and whether the interface can be used to compute the degree of influence. I could not find any documentation of sensitivity analysis in SMILE.
Sensitivity in SMILE is officially public, but we don't have the documentation yet. I'm attaching a program which compares the output from SMILE's sensitivity with the derivative values calculated numerically (vs. closed form solution from sensitivity).
The syntax for the program is:
derivative xdslfilename targetNode [targetNode...] [evidenceNode:outcome ...]
For example, assuming that you're using the hepar.xdsl from GeNIe's examples directory:
derivative hepar.xdsl THepatitis gallstones:present transfusion:absent
Note that this program doesn't print any error messages related to invalid input parameters, if you don't see any output, check the node identifiers.
Look for the use of DSL_sensitivity class in the code; post questions here if you need further assistance.
derivative.zip
source code
(3.4 KiB) Downloaded 1858 times
amirsad
Post by amirsad »
Thank you very much for the quick response and sharing this program, it helps a lot!
I've got some questions:
- In the function DSL_sensitivity::Calculate(DSL_network &net, bool relevance), what is the relevance argument standing for?
- In GeNIe's sensitivity analysis you can set the the percentage of changes of the parameters as Parameter Spread. Is this also possibe in SMILE?
- Using SMILE, I perform sensitivity analysis on a Bayesian network model which is learned from data using Clustering inference and EM. When I change the random seed of the EM learning engine, I get every time a totally different result of sensitivity analysis, although my binary classification results are quit robust (in numbers, running with 3 different seeds I get an AUC of 0.89, 0.88 and 0.87; but the mean sensitivity of an example node are 0.28, 0.04 and 0.06). Does it really mean that the learned model relies every time on a completely different set of nodes, and nevertheless achieves the same good results?
Relevance parameter controls the network decomposition performed before sensitivity is calculated. With relevance=true (default), each target is set separately. With relevance=false the internal data structures are created for all targets at once. The value of the relevance parameter does not change the calculated sensitivity values. The parameter is there mostly for us to verify that we get correct results using both approaches.
The spread is applied to sensitivity results, so it's up to your program to do that. Sensivitity gives you the coefficients in the equation t=(a*p+b)/(c*p+d). If you need to know how much the target can change, you need to assume how much p can change, hence the spread in GeNIe. Note that the t is monotonic assuming p in [0..1].
I think this is a possiblitity when you start EM with randomized parameters. You can try running the program I've attached on the learned networks and compare the sensitivity output with approximations based on numerically calculated derivatives. If they agree to a good degree, you can be sure the effect you're observing is real (sensitivity differs for EM outputs based on different seeds).
